Rebuilding power antenna
Randy Hagins
I am in the process of rebuilding my power antenna. Just wanted to know what grease is recommended. I was going to use white lithium grease but what I cleaned out of it when I disassembled it was a dark color . Thanks in advance.
The dark grease that you are referring to ,is dielectric grease. GN applied that to most of there electrical components that was susceptible to moisture & corrosion. That lithium grease will work perfect on the antenna mass. Wish you well on your project.
Thanks for the response. I should have the parts here today, anxious to get it together!
a tube of dielectric /tune up grease is like 5 bucks at ace or the wally
I used Teflon super lube on my rebuild with a steel cable but something is amiss. Worked great for a few months but last time I had it out the antenna only extended 10-12 inches and stopped. Retracts fine, I may have to tear it down again.
Sent from my iPad using Tapatalk Pro
