SignUp Now!yes and no... rightstuff RTV not silicone, I dont use the rubber sidee seals and pins ,Pacecarta, are you saying use silicone instead of the rubber side cap seals with metal pins?
The leak was the rear main seal for sure. Valve covers and intake were always dry. I measured the offset of the halves with a dial caliper and set them at .250.
caliper ..really? ..thats just silly
hard to believe you couldnt find anything?? ..try google and add turbobuick works great
heres one http://www.gnttype.org/techarea/engine/rearmain.html
heres my go at it
factory is rope , replace with felpro neoprene BS46013
a for best way , really only one way and its lotsa fun ..
get car on a lift ,
remove crossover pipe and converter shield
drain and drop oil pan.. lotsa fun..its tight fit with stock old motor mounts and you may need to raise engine a little and rotate crank to get pan out
pull rear main bearing cap ..mo' fun
pull block half rope seal from block ( more fun dont scratch crank ) they sell a sneaky pete for this but ive never had to use one , push seal in on one side grab seal at other side with needle nose pliers
clean block sides and face , hit with blast of brake clean to get rid of any oil
slide the new seal half into the block around the crankshaft
clean main cap thoroughly ( dont damage the bearing shell) , install new seal half into cap and apply RTV sealer to side cavities and a smear on cap face , put some assembly lube on bearing face ..dont dilly dally , reinstall main cap being careful not to knock the bearing shell loose
torque cap bolt to spec
squeeze more sealer up into side cavities until it comes out the corners at top
clean up pan and pan rail of block ,
install pan with new pan gasket
replace crossover and converter shield
fill with oil and prime engine before firing (disconnect ignition module , pull spark plugs , crank and verify oil pressure )
replace plugs and fire up
