turbokinetic
- Jan 29, 2008
Hello. I have made a video showing how to re-seal an R4 compressor. It is on an A-body car but I know the LC2 engine also has an R4 compressor on it. I hope this will help someone to repair their compressor economically.
One problem with the units purchased at the auto parts stores is, the rebuild shops are under pressure to do it cheaply and they may use low-cost parts to repair the unit; in particular the shaft seal.
Often the R4 will start making noise and fail mechanically before it needs re-sealing. But on the off-chance you have one which is still tight and only leaking; you can re-seal it with a new double-lip seal and body shell O-rings.
I did fabricate one special tool to press the shell off the compressor. Other than that, the other tools were commonly available.
I mention in the video, the seller who I purchased the parts from. I have no relation to him. I want to provide references so that if you want to recreate the results I got, you have a starting point in your search for parts. I hope this does not make people consider my video to be inappropriate.
I plan to do a video on the V5 compressor also.
Sincerely,
David
Sincerely,
David
