it says on the site that you can use this with a BSTC unit(which I happen to have) and have a larger range of boost control. How does this thing hook up? Do I need two WG solenoids for it?
Yes...you'll need two solenoids. I made up a little bracket with a piece of metal strap to hold both solenoids on the original valve cover bolt. Plus you'll need some vacuum hose and vacuum connectors to plumb up the lines.
When you hook up your 2nd solenoid, turn your BSTC down to min and adjust up to where you want it. For instance, your current knob setting may have your boost set at 16 lbs. and with 2 solenoids it may be 20. Word of caution.....the knob will be REAL sensitive and a slight adjustment will make big changes in your boost.
