Questioning turbo size
3500 is high but with that turbo it should be a hell of a lot more fun on the street than a 2500 stall. If it’s a PTC 9.5 it should still couple ok on the top end
Also what I thought Especially since it is a non lock up.
Only put 350 miles on it last year.
It is a little more than I wanted but got a deal on it that made it easier to at least try it.
Wondered what VSR turbo balancing was so I looked it up on U-tube.
Found it very interesting.
should lite up good.if your not looking to squeeze every tenth out of the car and run it over 100mph all the time being on the looser side is not a bad thing.we used to run ac 9 inch 3500 to 4000 stall on 66gtq and 70 gtq to get the hit.its just with the converters now you can have the best of both worlds with loose down low and lower slip up top and lower stall for street driving.
I have the turbo back from Turbonetics now.
Have been told no one makes this turbo any longer, but Jegs and Summit still have them listed for sale.
For some reason they sent me all the parts they changed / took off.
Now should I sell it ? Or trade it for a smaller turbo as they told me it would be cheaper to do it this way. ?
Now should I sell it ? trade it ?
what exactly was done?
They replaced the center section.both bearings, and a seal. And some other parts I don't recognize.
For some reason they sent them to me as well (the old parts). If they were not out in the garage, I would of taken a picture of them.
Will later.
Don't plan to put a metal shield on it and I should have told them to leave it off.
So. I can say it is new.
Will later.
Put it on and see if you like the combo with the new converter.
OK, I let the dogs outside for the 90th time so I went out with them to take some pictures in the garage.
The longer bearing is locked up and the case it sits in is scorned.
It has to be better and spool faster.
Have the turbo back on and waiting for spring. Going to be a whole different car.
