question
jlat
hello people; Is the guy that made alum. rad and a twin fan set up still a vendor here? His company name was like Aralco or something like that that started with an A.
IBBY
Pronto
Chaos is a ladder.
He's gone. Cold Case (stock looking with both trans and oil cooler) sells one that's similar to what he sold. Vendors here sell it along with a fan set up. There are other replacements sold by vendors here and there is a plastic tank version with both coolers on Rock Auto. At the high end is BeCool. If you don't want the oil cooler there are other options with the trans lines going to the engine side of the radiator.
grass doctor
Dream Catcher
alradco no longer available ....a reasonable price ...very good choice is the champion one ..the f body requires external trans or oil cooler cant rember which...the other one on rock auto requires mods to trans lines as they will hit the ac condenser ...check this thread out for the champion brand
jlat
hello people; I got his twin fan set-up and quickly holding it up to my stock set up and his mounting points are not the same as stock. I was wondering what the deal is.
IBBY
~JM~
Wrinkled Member
Alradco radiator & dual fans fit into the OEM upper & lower mounts without modifications. Sandwiches in place.
Pronto
Chaos is a ladder.
Aftermarket duals need custom mounting. Easy enough to bend a few tabs up to mount. Are you running the stock set up with both coolers? If so then you need a stock replacement. If you want to eliminate the oil cooler you can go with a regular G body radiator. The lines will need to be modded but again no huge issue.
jlat
hello people; I believe his name is on the box so when I get home I will know. I got the item a while ago and never put it on the car.
IBBY
I don't know about that and the mounting slots made with the Alradco are not close at all.
~JM~
Wrinkled Member
IBBY
The Alradco radiator & dual fan assembly dropped into place, no problems. That is why I bought that design.
jlat
I have a 86T. I wonder if there's any changes with a GN? Was your locating points slotted?
IBBY
jlat
hello people; I heard maybe 70 degrees here in Mass. on Sunday. I'll be looking better at my situation soon but I'll be back with what I find..
IBBY
jlat
hello people; I do have a alradco product. To any one who has there dual fan set up. Could you give me some overall dimentions. What I have measures 26" wide x 18" high with lead in dims. of 3.500" from edge to center of mounting points. Maybe he made dual fans for more than one type of car? Funny the wire harness instructions talk about connecting the Buick conn.
IBBY
jlat
Nope. Paid them for a radiator and never got it
hello people; That sucks but going to there phone number I got on line a women picks up and says leave a message. I did and I will be calling them again.
IBBY
Antbankstwo3
I am in need of a stock replacement radiator. Does this one you mentioned directly hook up to stock engine oil cooler lines and trans cooler?
I was thinking of Fbody as well but don’t know what it takes to make engine oil cooler lines work.
