QUESTION
DOUBAD RACIN1
I have a 85 hot air, 86-87 ecu,
60lbs injectors, ta33 turbo,
Direct scan, and msd boost controler..
My question is do u have to use a maf...
If not what do i need to do to bypass it...
Thanks for the advice...
Get at Turbotweak SD2 chip. Do your homework to see what you are getting into first. This is a lot more complicated. Having been in your position before (same car) it is overkill with minimal enhancements. I went with an LT1 MAF and a translator. Good luck
