QA1 Rear Shocks, Single Adjustable
GNVYUS 1
Low miles on the shocks, definitely less than 2k miles which is like a ton of parts on this car. The car literally sat from Summer of 2010 until I got it back running Jan 2019 then I took off in the Summer for coilovers.
I had PST lowering springs on the car, maybe 1" drop.
These appear to be the model offered 12 years ago, Can you provide the original purchase date?
Like I mentioned in the thread post, car sat for 9 years so these are probably around 2008. If the board wasn't a disaster you'd find threads of my engine trouble back then and when I called it quits for a while.
I keep all receipts so I'm sure I could find it if you're serious about buying. I've been a board member since around 2002 so I'm not some young scammer by the way.
Mike
interested and concerned about considerable dent in upper shock housing. closeup view indicates possible damage to area
around gas seal for piston rod. typically gas seal is set lower on housing. what's your opinion?
No leak ever, don't see any and never wiped away anything either.
Actually I didn't clean them so that's how clean they are which would name sense as I mentioned super low miles and car sat.
I'll find receipt but they're probably late 2000's and QA1s don't suffer from poor quality control so I'm not pushing off a dud here.
Receipt says bought in 2008 from Summit Racing.
Bump $190, shipping is probably around $25.
These are $320 new. Less than 2k miles on them and no leaks.
