Your pressure switch might be bad!!! Do this to check it. without the key on, pump your brakes 10 times or more to replease the pressure in the system. With everything plugged in and a new fuse in place, just turn the ignition key on, do not start the car and listen for the pump to begin pressurizing the accumulator. As pressure builds, you should hear the pump begin to strain under the pressure, then shut off about 15 seconds or so later, if you here it cut off then on again, so on and so on, or never shut off at all and the pump sounds like it is really getting pulled down, I would say the pressure switch is bad hence overloading the fuse and causing it to pop. If the motor runs all the time and does not sound like it is pressurizing anything, maybe the pump is going out or the accumulator and mastercylinder assm. have a problem. just my 2 cents. Let me know if you have questions....
