Hi guys Bison basically had it all covered. I haven't done performance or temperature test yet. I gotta buy a temp sensor to feed my auto meter temp gauge.
Just a quick note though on my 17 blade non lock my cruise speed at 55 mph is 1800 or so rpms on flat road.
But how long does roads stay flat here in south GA. lol.
slight inclines could take it to 1825 and slight declines @ 55 to 1675 rpms. 1750 average.
I came from a 9/11 i know my car turns over faster on the crank as if i have no converter on the flywheel
I cant tell any shifting difference at lite throttle , drives just like a lock up to fourth. I think with the lock up my rpm ranges was around 1400-1600 same scenario's . ( tires 275/60/15 with 25psi of air in them).
So again with my 200r set up driving out of town (30/40) miles one way looking at rpms on scanmaster @55 anywhere between 1775-1800 mostly n lik i say up/down grade will take it either way a 25 30 rpms. I drive 55 to save gas....
I'll report back with the other two results when i get to them. No spooling problems either. At 21 psi actuator set at I can brake boost to about 3000 before creeping forward. That's all i can think of for now. I have an external cooler bypassing the radiator i'll get n giv measurements when i do the temp test. Im out.
SO FAR: THANKS DUSTY.
