NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
I ordered a Window Racer from Kirban's a ways back. I installed it last week or so. Plug and play install with a ground (for those that are curious). The box itself has a slot to receive a 30 amp fuse. And it also has two LED lights on it. Red light indicates "power". Green light indicates "active".
When I insert the fuse the red light is lit. But if I wiggle it a bit it seems that I can get the green light to intermittently flicker. But when wiggling stops, and the fuse is fully inserted, and left alone, the red light stays on. And I believe that this is exactly how it's supposed to be.
Problem is, when I activate the power window switch, nothing happens. The red light stays lit, but the green light does not come on. The windows aren't moving faster.
But yet, I can get the green light to flicker when I wiggle the fuse, even when I'm not using the power window switch.
What the f#ck?
What the f#ck?
