Precision turbo 7475
D Mitchell
Changing set up and selling a few parts.
74 mm Turbo .63 exhaust 3 bolt $375 shipped. No shaft play. Seals bad burns oil
Chrome turbo shield $75 shipped
Old turbonetics wastegate / down pipe
Can you PM some pictures ? Also do you know what millimeter it is?
Turbonetics Racegate wastegate #10307
They feature a 1.625 in. (42mm) stainless steel valve and the proven Deltagate actuator. Turbonetics Racegate Wastegates 10307.
Was it working when removed? Might have to get it rebuild. What springs comes with it? What boost did you run?
Would you take $40 shipped?
It worked perfectly, just changed the set-up. Not sure of the spring but I was running 20 psi on pump gas and 35 psi on e85
Great! I will be running around 21lb . So that should work.
Will you accept my offer? I don't need the piping so if you want to remove it that's fine. will save on shipping cost.
Paypal ready
