Powerlogger and converter slip
broke
broke
Can someone give an explanation on how to use this function,
like what values to plug into 3rd and 4th to get an accurate calculation. Thanks in advance.
Try 46.5 for 3rd, and 31 for 4th. If you have a locking converter, you'll see how close those numbers are when it locks, If close CS should be close to zero when locked.
On the F3 page, in the Analog Input Settings area, click on the Adjust button.
Thank you, with 46.5 in 3rd my converter got to 6.5 at just over 5000 rpm. You can see it getting tighter as I gain RPM.
the converter slip is just calculating on the RPM and MPH data, so you can go back and look at old logs and see the slip in those also.
Bob
Thanks you guys, I will try it. I still have a lockup converter but no logs recorded with it locked. I am assuming I should record while just cruising with the converter locked to check these values?
That would help. Should read close to zero with tcc locked.
