87GN 98GTP
Andrew
- May 29, 2008
It keeps leaking around the gasket on the lower area. I've tried more torque, new paper gasket, rubber gasket and hi-temp gasket maker. Every time it leaks through the lower area of the gasket and out the side and lower bolt. I take the gasket off and u can see the oil seeping on the gasket same spot. I checked the aluminum return line and thought i saw a pin hole size but was wrong. Checked the flanges on turbo and return line and they look fine. But was also weird after trying hi temp gasket maker, didn't start the car and a couple days later saw oil seepage around the same area without the car ever running? I've almost given up
