Just talked to Cottons and he says its my regulator so im working on that now...I already re-wired nice and mounted pump on a bracket now im wait for accurafab regulator.
You only have -8 feeding the pump?! Wtf dude?? You spend all this money on an engine that makes 600+whp and you skimp on the fuel lines...wtf dude, seriously..
Stock being a cheapass and return the pump and buy one with a fuking -10 feed to it. If you have a -10 lines and then you have a -8 adapter right in front of it, it doesn't do much good, does it? Unless I'm missing something here.... but it looks like you have a -10 to the pre-pump filter, then a -10 M-to-F on the filter and a -8 M-to-M on the pump connecting to the filter. Why put that restriction right there before the pump, even if it is for a little bit?
If you unscrew the regulator nut all the way so that the regulator has no influence on the fuel pressure, and turn the pump onto high flow and the pressure rises, your regulator is too small. If it stays the same, then its fine. Look at the fuel lab 565 line of regs, or the Aeromotive #027-13113. Both have -10 returns and will flow enough for 2000+hp.
Also, did you pull the filters in the injectors? What size are your pre and post-pump filters?
How many 90deg fittings do you have? Are they hard elbows or smooth AN- bends?
The wiring is also crap, like someone already said.
Ony my own rig I plan on running dual of these FL pumps, or even the 42401's and that aeromotive regulator. The only 90deg's I'll have in my lines will be if they are an absolute *must* and will be AN-style smooth bends. My lines may cost almost as much as a single pump, but I'll be damned if they have any restrictions in them!
