turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
Packages i.e.
Cooling system
a. radiator
b. fans
c. RMI - 25
give or take on the combo maybe add all hoses, option to have external coolers and have them available with it, hvy dty water pump, t-stat, billet neck, etc.
Exhaust
a. downpipe
b. cat/testpipe/cutout
c. cat back exhaust
have it aluminized or stainless for a few bucks to be saved or the good stuff.
ignition
a. plugs
b. wires
c. die electric grease
d. hi po coil pack
Give or take
suspension
a. air bags
b. springs
c. shocks
d. poly bushings
e. traction/lift bars, boxed, etc.
give or take
turbo
a. turbo
b. oil feed line
c. drain line
d. fittings
e. gaskets
f. bolts
valve covers
a. valve covers
b. gaskets
Timing chain
a. hi po timing chain
b. one peice cover seal
c. oil pump kit
d. needle bearing thrust/cam button
e. sealant
give or take
gauges
a. pillar pod 1, 2, 3 gauge
b. gauges
c. connectors, fittings, lines, wire, screws, etc.
I know this exists partially with the console pod.
Tach
a. large or small tach w or w/o shift lite
b. bracket for clean install above the radio to the left of the a/c vents or above the instr cluster w/o drillig holes
c. proper interface/module for proper operation
d. all hardware for install
give or take
Chrome
a. could be a lot of various stuff. But, have several popular chrome pieces together.
This is some I thought up quickly. I think it would go over and be easier on the end user.
Also with all packages detailed instructions.
What does everyone think ? feedback please
Cooling system
a. radiator
b. fans
c. RMI - 25
Exhaust
a. downpipe
c. cat back exhaust
ignition
a. plugs
b. wires
d. hi po coil pack
Give or take
suspension
a. air bags
b. springs
c. shocks
d. poly bushings
give or take
turbo
a. turbo
b. oil feed line
c. drain line
d. fittings
e. gaskets
f. bolts
valve covers
a. valve covers
b. gaskets
Timing chain
c. oil pump kit
e. sealant
give or take
gauges
b. gauges
Tach
give or take
Chrome
