Sam Colalillo
low 9's w/ a 109
$ 650.00 Balanced rotating assembly with less than 1,000 miles
Includes…
Crank is standard/ standard, from a car which has 10,744 miles on it.
5.96 Molnar rods with ARP 2000 rod bolts
Pistons are forged .020 free floating Forged Aluminum 8.5:1 w champion alum heads
New flywheel
Harmonic balancer which assembly was balanced with.
Double roller timing set
$ 215.00 MAF Translator for 86/ 87 Turbo Buick, with the AC Delco ZO6 mass air flow sensor. This is the large 4” sensor (21 213-4160) with built in air temp sensor. Also included is the Casper adaptor harness which makes this setup a complete plug and play upgrade. It even allows you to plug you factory air temp sensor connecter into. Also comes with the hose couplers at one end which will allow you to put this onto 4” mass air flow pipes.
$ 125.00 Scan Master for 1986 / 87 turbo Buick
$ 35.00 Powder coated stock valve covers with K&N breather
$ 125.00 Alky kit
Includes everything pictured, was told it worked from previous owner of car.
$15.00 known working 2 bar map sensor
$ 45.00 Stock inter cooler with Dutwieler neck
$ 245.00 Set of 6 flow matched 80lb injectors (Siemens).
These injectors have less than 1,000 miles on them and are less than a year old.
These may look skinny but they fit perfectly in the Turbo Buicks. Good for cars looking to go 9.80's to 11.0's in the 1/4 on race gas, or down to around 10.50's on E85 (maybe faster). Requires no ECM modifications (besides a matching chip). These are flow matched to within 1% of each other to prevent some cylinders from being leaner than others. Very good street manners for an injector this big, almost as good as the 60's. Be aware that a single in tank fuel pump can only supply enough fuel for 60lb/hr injectors. So if you don't ever plan on changing to a double fuel pump setup, or external setup, then there's really no reason to use the 80's.
TurboTweak adjustable chip version 5.7, custom made for 86/87 Buick
$45.00 Pair of Turbo Tweak chips.
Adjustable chip version 5.7, custom made for 86/87 Buick
One is for 91 octane with above injectors
second one is for 114 octane fuel
$25.00 turbo tweak chip for alcohol with 60# injectors
version 5.6
$25.00 test pipe 2.5” exhaust
Includes…
New flywheel
$ 125.00 Alky kit
version 5.6
