If its a black car you can paint in parts . I always use the same steps on all parts same amout of air pressure coats of base and clear .
3qts did mine, jambs and all. I seal it with black primer and painted everything off the car.What's the typical amount of paint need for a complete repaint of a gn?
I am planing and budgeting so I know how much to set aside for materials.
Sounds good just after body filler spray epoxy on any bare metal spots again.Sorry for all of my newbie questions on paint. This will be my first venture into paint work and I want to do it right.
Just so I am clear in my head..........
1 - Sand down to bare metal
2 - spray epoxy primer - High Build Primer?
3 - Do any body work with filler
4 - Spray Urethane Primer (Would this be a 2K primer?)
5 - Base Coat
6 - Cleat
7 - Wet sand with 1500, 2000 , 3000
8 - polish
Does this sound right?
Very good advice, also get a bunch of different sanding blocks (long and short). First blocking use longer blocks with coarser sandpaper (180-220). Reprime and block with 400 if straight.A very good tip is use a gide coat over your 2 k primer spray a light coat of dark primer over top of your lighter 2k primer when block sanding the darker primer will show all your dings dents and flaws
I dont like epoxy primer on a body. Epoxy is an old technology. If you keep it thin, it is ok to use. The paint companies dont recommend using filler over it anymore either, that is an old 1990s technique.
To get a flat finish, you will need to block with 1000 or even 800, then 1500, 2000 blocked, then 3000 on a DA. I like to buff with a foam pad, and final polish with an orbital.
