p0894 (transmission component slipping) possible problem with converter clutch. did you notice if the converter clutch is engaging?Any ideas on this trans code? Fluid is full and pink. It shifts hard in all gears only after warm and if i shut it off for a few minutes and then drive it again it will shift fine for awhile. 07 Chebby 3/4 ton van. 100k miles.
That's about all you can say at this point. You'll need a scan tool to check the percentage of slip but it's got to have 3 seperate cycles to verify the slipping componant. Jimmy's right though, it's a slip issue inside the tranny.what usually happens is the pcm will detect slippage, dtc sets & pc solenoid commands full line pressure, hence hard shifts, you need to look at tcc slip speed while driving constant highway speed should be close to 0 rpm with converter clutch engaged
Slip speed is too high. Needs a convertor and should inspect channel plate for checkballs beaten into the plate. Internally my bet is the unit is fine and prob does not have any electrical issues. See this on G vans some with as few as 25k miles still under warranty of course.what usually happens is the pcm will detect slippage, dtc sets & pc solenoid commands full line pressure, hence hard shifts, you need to look at tcc slip speed while driving constant highway speed should be close to 0 rpm with converter clutch engaged
