OE ECU future ?
I was looking at the HP option for that reason. Didn't know about the trans issue. I'm keeping my 200, just can't give up OD.
The Dominator and the Terminator X Max have control for DBW and trans like the 4L80. The Dominator and the ECUGN have a lot more inputs and outputs.
The HP/Terminator X have 4 input 4 output. I went dominator because I was already out of outputs by the time I had the basics that I wanted (Fan, 2nd Pump, Boost+ Boost-) 2 of the 4 inputs were also taken (Flex Fuel, Dome Pressure) and I still want to put in VSS, Trans Temp among other things.
Definitely something to consider... The Dominator does seem appealing but it is a lot more $$$ than the HP. I guess its all in what one is trying to accomplish. I was concerned about the HP with only having 4 inputs and 4 outputs as well.
You just need to be able to trigger the lockup solenoid
Anything can do that
The 200 just has electronic lockup.
If you're only a novice at tuning, the OEM ECU with the correct TT Chip and a Powerlogger is the way to go.
Simple, reliable and will go into the 9's without a hiccup.
For holley hp and dominator it's an ntk
You can choose either bosh or ntk on the hp/dominator although I think the NTK is supposed to be the better one for turbo applications (mine has bosch in it right now).
The Ntk is the really the only choice on a dominator setup from I have seen for it actually to run and respond correctly.
No sense having a system like that and running it on the slower wideband even if it will run.
