ODDS & ENDS (Some Hard to Find) $5 to $25
Trader history for m233roller (1)
m233roller
Here's a bunch of odds & ends I'd like to get rid of.
PIC.#2461 A pair of rear bumper shocks that are all redone. Nice! $25 each.
PIC.# 2462 Mint gray under the steering column cover. $25
PIC.# 2493 Painted gloss black overflow & windshield washer bottles that are almost new. $25 each. Nice turn down you can bolt on if your running an electric dump. $20. Both left & right refurbished w/s side moldings. $25 each.
PIC.# 2494 Very nice stock vacuum ball. $20. New Kirbans shift plate overlay (no piece for the ash tray)$10. Nice passenger side under dash covers. $25 each.
PIC.# 2495 Nice upper oil cooler hose. $20. Little wiring heat shield that goes on the back of the engine. $10. 6 new clips for the front headliner molding, 2 new for the rear molding & only have 2 of the clips that hold the thin metal panel outside between the back glass & trunk lid. $15 for them all.
PIC.# 2496 Rear speaker hangers $10 for two. 4 long & 2 shorter timing cover bolts that are sandblasted clean, $10. Good a/c dryer but paint is rubbed off on top. $10, Like new pack of 8 taillight nuts. $15 a set., Little gray Y for the boost line $15. Very nice stock idler pulley with almost new bearing. $15. Nice intercooler fan hub (hub only) $10.
PIC.# 2497 Like new never used ash tray for rear of drivers bucket seat. $15. New diaphragm & spring for your FPR. $20. Nice set of U joint clamps & the 4 bolts. $15. Six coil pack screws & the 3 nuts that mount the ignition module. $5. Chrome door escutcheon for drivers side mirror. $5. Nice redone passenger side relay cover & mount. $15. Buick grille badge but the black part of it is mostly gone. $5. Nice hood safety latch. $10.
PIC.# 2498 Nice stock turbo inlet bell with rubber block off plug. $15. Two sandblasted clean bumper mounting dog bones. $15.
PIC.# 2502 Nice complete set of dash tell tells. $20.
PIC.# 2505 Very good hood release cable but the white lettering on the handle is weak. $20.
PLEASE NOTE ALL PARTS ARE PLUS SHIPPING & PP FEES.
THANKS MIKE
