the 4 wear washers that are closest to the sprag are well within spec with a feeler gauge but are worn laterally, egg shaped the holes and wobble around. All 4 washers did this, all on the same side of the planet. Everything else about the planet is cherry as this is a low mile 87 brf that I'm 99% certain had never been apart. I have a new set of wear washers for this but my gut tells me to replace at least the carrier assembly. I'm no pro but I've seen a few of these, couple of which had been beaten on quite mercilessly, and never seen this problem before. Thoughts?
