Rahob
- Jul 14, 2013
I have just finished installing the Axis Interface along with the Axis chip from Turbotweak. I have a Bluetooth scanner from 1320 Electronics and both ALDLdroid and ALDLscan Apps. I adjusted both the TPS and IAC per chip instructions.
I have noticed my 02 readings seem to be drunk, and I'm not running any alcohol. They are bouncing all over the place, I thought it might have been a bad O2 sensor, so I replaced it today. I guess there's always the possibility I managed to get a bad one . After installing the 02 sensor, I had disconnected the orange computer wire for a minute and plugged it back in. Idled for a while in my garage until it got to up to temperature (at least 160) I didn't drive it around at this point but I noticed the 02's whonky. I also noticed if I slowly pressed the accelerator while in park, there was a little hesitation for about the first quarter inch (6.35 millimeters for those in the metrics parts of the world) even when I was in drive as well.
Onto my drive, I went for about a 15 minute drive to town, parked for about 30 minutes then returned home for another 15 minute drive (this is when I took my readings). And these were done all in just drive (3rd gear max). Improvements I've made to the car besides the Axis interface and Axis chip are stock intercooler with duttweiler neck and redid the Air intake with a LS1 MAF sensor.
Besides new plugs, wires, fuel filter, tranny flush etc. spring cleaning stuff about 2 years ago (less then 1000 miles have been put on since then).
The readings on these links for the "MAF" is double what it says, I confirmed this with Eric at TurboTweek. So when it says 3 while idling it's actually a 6.
Any thoughts on why the 02 is so low?
ALDLscan road test readings;
ALDLscan Idle readings;
ALDLdroid idle readings;
