After multiple days of hard work, i finally got her to run about 20 minutes ago!
What i ended up doing is removing the harness from all sensors removing the tape, checking each wire/plug and visually inspecting each pin. I traced and verified each ground, i even removed the cruise control harness. I did see one funky corroded pin on the cruise control bulkhead. I sprayed contact cleaner on all pin's and mating surfaces. With a compressor i blew pressurized air into all sensors and plugs. I even did this too all relays on driver side, and on passenger side by the esc module. i also dropped the column again and checked my ignition switch installation and removed plugs to have a quick visual inspection. I removed and re- installed the crank and cam sensor reset timing after cleaning. One thing i did notice was the reluctor ring which slides thru the crank sensor was a bit dirty on one side. I checked every single pin on the ECM for verified voltage i also re-checked every single pin on ICM, All was good. I removed and inspected every single injector plug interesting enought #6 plug was kind of moist inside?? i cleaned all injector plugs and hit them with air as well.. Once i had finished putting this all back together i turned the key and she fired right up.
I hate to fix things like this without understanding the root cause of it but i can tell you one thing the cleaning of every sensor and plug really i think helped me out. Maybe she had a few little issues remember the car has been sitting for a few years non running. Well at the end i ran thru 2 cans of CRC contact cleaner. Since i was already their i re-tapped everything real nice as well. Then the final touch of the compressed air really helped with making sure all was clean.
Thank you guys for you help, i will make it a habit to clean the engine harness and contacts when buying a parked car that hasnt run in a while.
Opinions on what might have fixed this? Maybe the dirty reluctor ring it had a little spot of corrosion i sanded it down and cleaned it, maybe?
#6 injector plug was wet / humid?
Cruise control had a corroded pin on the bulkhead?
I'm glad i got her running now i need to re-pack the oil pump with vaseline and i will clean her up and post some pics,
