No spark or injector pulse
slowGN
Hi all,
My dads cars will not start. It cranks fine but it has no spark or injector pulse.
We first swapped the coil pack and module with one out of my car, Then we replaced the crank sensor. Using Caspers cam tool, the cam sensor seems to be working. We have data reading on the scan master so I would think the computer is ok.
any ideas would be great on where to look next.
Thanks alot,
CJ
Did you open the top of cam sensor (take off the cap) to make sure the metal ring didnt bust the tab & it just spins free will now? happened to many including me.
When you replaced the crank sensor did you use the slot farthest from the end?
I did take the cap off the cam sensor. Its spins with the engine.
I'm pretty sure I put it in the same space as the old crank sensor. I'll have to double check that.
Thanks for everyones help.
