65psiboost
- Oct 25, 2017
hi guys/girls happy holidays to all!!!
Ok, I apologize if this was already covered but I did do a search and couldn’t really find what I need.
So we did some Christmas shopping in the GN. After we loaded up the trunk with gifts and groceries the car wouldn’t start and I had absolutely no power to the tail lights or fuel pump. After taking everything out I noticed the Circus of weak and frail wires that I guess I accidentally pulled right from the 2 male plugs seen in the pics.
With the help of google I was able to figure out which wire was the fuel pump trigger and after cutting some insulation off and twisting them together I was able to bypass that Corroded connector and got the car started up. My pump is hotowied but this was the trigger wire from the ecu.
Later on today I plan to replace all of that frail trunk harness wire with some better quality wire and loose that double connector. but unfortunately I have no idea what wire goes where because the whole wire pulled out of the connector from the weight of the cargo we put in the trunk. So I could really use a schematic or diagram of what color goes to what color before and after that connector. I don’t think the colors actually match up after the connector. So any help would be greatly appreciated because I had to drive home at night with no rear tail, stoplights, rear turn signals,or reverse lights. As of right now I have no rear lights.
Please see the pics. I had no knowledge of this mess because it was nicely tucked away under some nice aftermarket trunk interior covers.
Thank you and have a blessed day
