Ok, when I put the slider to Hot on my car, cold air blows out. I checked the water valve (which I had replaced with a new GM one a few years ago), and the plunger definitely works when the slider is moved from Hot to Cold and vise versa. I checked the hose from the valve to the heater core along the firewall, and the hose gets hot, so it looks like the valve definitely works. Also, I can hear the shudder door move when the slider is moved, so I dont think theres a problem with the door or the blower motor..
Any idea what it can be? Could it be that the water valve went bad again? Heater core? Low coolant?
