NEW RACETRONIX 340LPH PUMP + SS SENDER COMBO
Racetronix
FEATURES:
  • Fully assembled and tested
  • All stainless-steel construction
  • New-style 90 ohm ceramic level sender resistor
  • Non-tapered pump outlet tube for maximum flow / performance.
  • Tubes have smoother radius bends for maximum flow / performance (1)
  • Dual 14-gauge circuits (vs. factory single 16-gauge ) for improved power handling and reliability (2)
  • Modular wiring harness allows for various wiring configurations / upgrades and simple repairs
  • Includes a new stainless-steel locking ring, OE-type tank gasket, rubber hose, hose clamps sound dampening pump sleeve
  • Racetronix 340LPH high-pressure/volume pump pre-installed
  • 30-micron graded-media filter sock installed
(1) A pulsator / dampener is not used.
(2) The Tyco in-tank connector fits Walbro and many other aftermarket replacement pumps. Please check polarity markings before installation and make adjustments as required. This Tyco connector will not fit the factory-style pumps with Delphi Metri-Pack 150-series connectors. The maximum recommended electrical load is 20 amps continuous and 28 amps intermittent duty. This high current capacity allows this sender to be used with all factory and high-performance in-tank pumps currently available. It is highly recommended that a Racetronix FPWH-006 fuel pump wiring harness be used with this sender in order to properly support the power demands of the Walbro high-performance fuel pump.
(3) May fit other G-Body cars with or without modification when being adapted to FI applications. NOT SUPPORTED BY RACETRONIX.
http://www.racetronix.biz/itemdesc.asp?ic=FPS-G7RXP340M&eq=&Tp=
Have been waiting for this. Do you have a link to the combo? Also is it on sale?
Sent from my SAMSUNG-S3 using Turbo Buick
Does this kit use the Walbro part number F90000267 pump? I heard that pump does up to 450 LPH and something like 1000 horsepower? Or is this a lower output pump? Cool setup regardless!!! I'm still running the old F20000169 pump which is only good for like 600 HP.
usa made?warranty ?
If you want US made then buy our sender with a Walbro 255 or 430LPH pump.
Our RXP340 pumps are made in the same place as the AM340, DW and AEM pumps.
We currently offer a 3-year warranty on this pump+sender combo.
Can you get the hanger with the digital dash sender or does that have to be purchased in addition to the assembly with the analog sender?
