New oversized TH400 center support with billet aluminum clutch piston
chris718
Increase second gear clamping force by 800 pounds .This support has been designed for use with all aftermarket TH400 transmission cases but will also fit a stock case as well . Improves clutch life by increasing clamping force and improved distribution of clamping force. Close to 18.5 inches of apply area resulting in 3700 pounds of force at 200 PSI.
Chris,
The center support appears to be machined for a thrust bearing on the direct drum, is this correct ? How much ?
Allan G.
