New LED Headlights are dim
DJ Ross
3
1
3
40
I installed a set of LED head lights (low beam and high) awhile back, I finally was able to take her out for a drive at night and they are VERY dim, I switched the connectors around when I did the install. They look great when your looking at them, and I’ve adjusted them correctly, they just don’t illuminate the road very well. And advice would be very appreciated. Thanks in advance.
earlbrown
runs with scissors
May 26, 2001
7,004
1,233
113
47
lagrange, GA
Any idea what the current draw is supposed to be on your lamps.
It sounds like you're powering them with the factory switch.
Chuck Leeper
8/10's of a century!
Staff member
May 28, 2001
11,863
1,510
113
Madison, Ga.
The cheapos are very often, poorly focused.
Not an adjustment that can be made, short of replacing them with a quality light.
Lots of them were originally designed to be used on a rickshaw, w/a top speed of 3KPH.....
Top Bottom
