New accufab = junk
Brad_H
I got a new accufab afpr from racetronix and installed it but it wouldn't go past 20 psi and that's with the adjustment all the way screwed in as far as it would go.....so I took one I had on my syclone and took it off and tested it and it works fine without a problem...so I know it's the new accufab not working.....and reading now I here there garbage units from the start....any mods that fixes them?
Jerryl
Tall Chinese Guy
Only fix for the new units is the trash can. Take it apart and post pics.
I tested a 2001 AF on the HA yesterday and 10 hours later, the pressure was still at 25 psi from 45 set.
Jerryl
Tall Chinese Guy
Those are two different regulators?
One is a poppet type and the other is a ball seat type.
bison
Moderator
Staff member
An oem regulator won’t have these kinds of problems. These things have a high defect rate. I’ve had a couple with problems. Someone else told me they found a staple inside the regulator after it failed to function properly. I’d bet you could test 1000 stock regulators and never find a faulty one even with a lot of use and sitting dry.
Grumpy
Thread killer
Wow... never heard a bad thing about them till now. Why didn't ya send it back to racetronics ????
Brad_H
S
so hows the factory 237 regulators?
