New 2004R gearsets & other parts
quickt
I have New gear Sets for the 2004R. With first gear ratios from 2.98 to 2.21.
2.57/1.54 Helical $550 in stock
2.48/1.48 Helical $550 In stock
2.57/1.54 Straight Cut $795 In Stock
2.48/1.48 Straight Cut $795 In Stock
2.41/1.45 Straight Cut $950 (All New)
New Direct Drum made from 7075 Aluminum 8 clutch basket Hard coated $600 In Stock
Coming Soon
2004R Front pump 30 spline input to accept TH-400 Converter.
2004R Front Pump 30 Spline input to accept LS style converter With a much better lock up clutch assembly.
Billet Aluminum Griner VB Manual Reverse with Pro Brake
Check the website for pictures coming soon
Lonnie,
Nice line up of new products!:)
Do these new direct drums accept stock width clutches and steels? Or what are you recommending/using?
Brian
The basket is set up for 8 stock width clutches and steels. You could squeeze 11 in there if you choose. The drum is setup for dual feeding only there is no inner seal. We are considering doing a complete forward drum and getting away from the shaft install on the stock drum. If we do decide to move forward we are going to change the clutch adding about 30% more width to the clutch. (Still in the thinking stage.) We are working on a 3 speed super stock type 2004R to bump heads with another very successful unit out there. Lots of neat things made for the new trans that can be used in the 4 speed unit.
Nice. I will have to get one of these and check it out. All is good other than the "dual feeding" part.;)
Thanks Lonnie.
Brian
