Need help older Maf Translator settings
1987T
Looking for 10's
Dec 5, 2011
321
25
28
Michigan
I have an older (Im guessing as it is not like the newer ones or the photos I have found for setting them) Maf Translator I have no paper work for it as it was in the car when I purchased it. (Hidden)
I have attached a photo of it all I want to know is what dial to turn and where it needs to be to work with the 85MM MAF I have
Thank you
1987T
Looking for 10's
Dec 5, 2011
321
25
28
Michigan
Ok so I just found one that match it on Turbo Tweaks site but where is the starting point on the dial? The top centered ?
Ttype6
3,296
242
63
60
Flint,Michigan
Thank you
That's a Translator Plus. Score! You can adjust fuel and spark. The New/Current Translator only allows for fuel adjustment. Set the first knob (Base MAF) to 6 for an 85mm MAF.
7 is 10% rich. 8 is 10% lean.
Post a picture of the connectors.
  • Like
Reactions: andresfel
1987T
Looking for 10's
Dec 5, 2011
321
25
28
Michigan
Turbo Bob has been email with me. The Translator I have has no settings beyond 4 (Really Old) He said to leave it on 3 but still same thing starts stumbles and dies. It has the 3 to 5 Plug adapter on the MAF. Im most likely stuck with the 3.5 LT1 Style MAF just wanted to get rid of the restriction between the Big Mouth intake tube and 4" Inlet pipe seeing I have the 4" Opening on the turbo . Suck is life I guess.
Waiting for Bob To reply again gave him info he asked for
Charlie Gaudet
Resident Jet Mechanic
Dec 20, 2015
81
30
18
35
Peabody, MA
Go speed density then
1987T
Looking for 10's
Dec 5, 2011
321
25
28
Michigan
Yup as soon as I have $3000 to spend (God knows when that will be) I will be changing the ECU to either Holley EFI Or ECU-GN From Turbo Tweak
Top Bottom
