So in park the IAC #'s will count down to 00, but at different times when I go into D with foot on brake they will go to 175 range and AR is about a 6-7, and the car will stay idling. I then shut of the car and do it again and in drive the IAC will count down to 00 and will not stay idling unless I apply a little fuel via the peddle. Only differ between the two is I turned the car off and back on again.
This has been an IAC issue I have been tryng to solve for a few weeks. I did try a new IAC. Seached for Vac leaks.
I do hear a Pssssssss sound for a very seconds coming from under the dash and behind the AC control area. this happens if I build about 10+ boost and let off. Then I hear the Pssss sound for a sec or two and then it stops or it keeps doing it but I just cannot hear it anymore. Could a loose Vac line to the AC be causing me this trouble? I assume any loose vac line would be trouble but could it explain the wild IAC behavior after each start up?
