Need a couple of torque specs
Mike T
Front pump to case and center support please:)
Also the band was at .090 on the original build and I've tightened it up to .055 now my question is how might the .090 have affected the 2/3? Wasn't quite a bind or a flair more like a split second hesitation at part throttle.......was fine at full throttle.
Lil Truck
I spend to much time here....
#2
Pump to case 25 ft lbs, I believe the center support is the same. Not sure about the band clearance causing the shift delay, but I would suspect pressure and/or timing problem.
Lil Truck
#4
The information I have came from an old ASTG video. I didn't have a chance to review it until this morning. It does say 25 pump to case, the center support is 20. I will probably reduce to 20 on the pump to case as a safety margin.
Thanks for the info Ineedagn!
Mike T
Thank you guys. Hadn't torqued the pump to case but did hand righted the center support to feel......bet I exceeded the recomened by 10
