its for the cruise control
a 4 contact blade circuit board (two contacts on each side) that comes from the turn signal arm when equipped with cruise control there will be a square black connector with a clip on the side for that blade to plug into
its bundled into the main harness that has all the strg column connectors , the harness is tapped up to a point above the column and all the wires to column split out to their connectors including the cruise connector with the white lock tab on the side
