I just bought this GN. Im getting like 8-10mpg. Some assclown put 4.11's in the rear before I bought it. I seem to have some leaks at the crossover pipe. I also need to keep the speedometer disconnected cause the speedo makes alot of noise and the needle bangs around. Ive heard that can keep the convertor from locking up, but I dont imagine it would slip this bad. I just filled out an rpm calculator for the 4.11 gears, tire height, and the 200-R4 tranny overdrive ratio. It says I should be at about 2400-2500rpm. Im at 3200 rpm. What gives? I wouldnt think the convertor would slip that much. The seller said its most likely a 2800 stall. The o2 sensor is new, and the seller used a scanmater to check everything. He said the BLM's are perfect, and it just passed smog with great numbers. It has a misfire problem at idle and low rpm's. it had a bad vacuum leak at the base of a couple fuel injectors, which I fixed. Please help. This car is my daily driver and I cant afford all this gas.
