Moving Sale on go fast parts - PTC, 6765dbb turbo, PPP shifter
Eticket
PTC 18 blade converter.... No issues.. Sold...
Precision 6765 double ball bearing water cooled turbo. This is the last of the Garrett water cooled center sections that PTE used and possibly the most reliable of them all. About 1000 miles on it. Cast wheel but good for at least 134mph in the quarter. Will include braided oil feed line. Does not come with turbo bracket $900 shipped.
Precision Performance Products 4 speed shifter with new bracketery and cable setup. Taking a loss at SOLD... This is close to a bolt on, but might need some bracket adjustment, etc.
Pricec above are PayPal gift prices...
Updated - converter and shifter sold.
If someone wanted to downgrade from a 70/71 HPQ, this is a good alternative....perfect for a mid/low 10 second build - as I have...no doubt it will go into the 9's with enough motor.
Does your 6765 have the H-cover and do the water lines with the banjo fittings go with it?
Did you order the turbo with the exhaust housing for an external waste gate? Surprised that the exhaust housing doesn't have a wastegate hole.
what you see is an rjc block off plate. sorry about that, the turbine housing is a normal
pte 0.85
