Motor mounts
1986 Buick GX1
GX1 #001 [The One and Only]
Apr 24, 2015
1,371
332
83
55
Manly IA
Tips or tricks on changing out motor mounts on one of these cars? Thanks in advance.
Put the car up on jack stands if it isn't already (Hehe) to give yourself some elbow room.
Disconnect the battery as the starter is close to the passenger mount. Do one at a time. Pull the long frame bolt out. Raise the motor a couple inches to make some room and unbolt the mount from the block. Reverse the process. Do both sides.
It will take a little while as space is tight. Sorry I don't have bolt head sizes, it's been a while.
As TurboTGuy says, use H&R motor mounts or stock mounts with the RJC Racing motor brace.
  • Like
Reactions: BoilerDeez
Top Bottom
