B budget_crx Member Joined Feb 26, 2007 Apr 1, 2008 #1 My friend just bought a lancer evolution with a maft pro installed, but no instructions were included. How do we use it as a boost controller? He wants to bring the boost down a bit from 29psi
R Real-T Member Joined Aug 11, 2003 Apr 1, 2008 #2 The full manual can be found on the Full Throttle tech site: NEW Translator Pro Manual - Full Throttle Speed Tech Support You may have to register to get in, but all the info is there too and you can ask questions as well. But to answer your question, ifyou hold the "PG" button down and scroll using the using the "range buttons" you will find the boost control page. When you are in that page, let go of the "PG" button and you can scroll through the individual boost control parameters. The details are in the manual from the website, but just trying lowering the PSI Set parameter down to where you need it.
M Mike Licht I was here first Joined May 23, 2001 Apr 2, 2008 #3 this is of course assuming the the boost part is hooked up. Check in with us at Full Throttle Tech and we will help you out Mike
