ls2 6.0 heads
boogeyman
4CED4
i have 2 sets of 317 casting number heads from a 6.0 ls2 motor these are a perfectt head for a boosted motor they have 72cc chambers to lower the compression so if u are using a ls1 shortblock they will lower the compression to aprx 9.2/1 asking 125 per set i have all the rockers and stands for the heads they are complete w valves and springs also
info
are you sure thats not a 6.0 liter truck head --- ls2 should be a 243 casting /
317 have the same port design as a ls6 head but bigger chamber --
info
how much are you asking and are you interested in trading for GN parts
asking 125 per set , the only stuff that i woud trade for is a alky kit , large low impedance injectors, or a decent boost controller
243 castings are of an ls6 and are sought after for ls1s due to better flow.
