m3x1c0
Bad luck Buick
uh oh! Noticed a little puff of smoke and oil smell when I reversed into my driveway a couple days ago and coming to a stop at idle today. I have occasionally noticed little whiffs of burnt oil smell once or twice before figured it was just my leaky turbo drain. Today happened once and couldnt get it to do it again driving up and down my block. Sniffed up the tailpipe and smelled nothing. My oil pressure is kind of low at idle when its really hot out. I think I have about 12psi pressure at idle and 50 cruising. 65 getting on it. Never gone lean nor have I seen any hint of knock except one time when I was tuning alky. (sub 2.0 KR at 12 AFR around 10psi.) My tune is rich and timing is conservative 17 at WOT. Im thinking when my turbo blew I might have gotten a little scoring on the cylinders. Also seeing some oil out of the breathers but nothing outside of normal.
Now I'm running 5w30 vr1. Think I will bump it up to 15w40 to see if it changes but also will be swapping to an Fbody rad tomorrow. I'm thinking with how hot it is here in VA and the light oil weight im getting blowby into exhaust or something. Turbo just rebuilt no shaft play, and motor is less than a year old. I'm sure I'm just a little worried. Car is pushing 30 pounds of boost with alky and high 9's AFR. Yes the pvc works, yes I have a catchcan.
Anything else I should check? Should I not worry about it? I am planning on swapping my compressor housing and turning boost down to 25 before I hit the tracks next month. Drive the car 4 or 5 times a week.
