Heres the info from racetronix Need to sell to pay my truck payment,, $275 Shipped.
Thanks for looking
blafler87@yahoo.com
Part Number 17113742 (OE # 17104988)
Static Flow Rate @ 43.5 PSI (300KPa) = 75.0 lb/hr / 9.5 gm/sec / 788 cc/min
Static Flow Rate @ 58.0 PSI (400KPa) = 86.6 lb/hr / 11.0 gm/sec / 909 cc/min
Dynamic Flow Rate @ 43.5 PSI = 1.75 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 2 Ohms / Low Impedance / Low-Z (Peak-hold ECM driver modifications required)
Cone Spray Angle - 22.5 degrees - single spray cone. Approximate cone angle for 90% of spray volume
> Click here for dimensions <
Silicon grease supplied to lubricate o-rings prior to installation
Ball & seat design with 6-hole diffuser disc. Same as MSD and Holley product.
Dynamically flowed and grouped to tighter tolerances than factory with Racetronix new injector flow bench
Thanks for looking
blafler87@yahoo.com
