I am installing the innovage LC-1 wideband with the DB digital gauge. I am also installing a translator Gen 2. The Gen 2 instructions show to connect the brown analog output 2 wire to the orange wire on the Gen 2 harness. The innovate instructions for the gauge install says to connect the gauge to the brown analog output 2 wire also. My question is does it matter if the gauge is connected to the analog 2 output also, or should I connect it separate to the analog output 1 wire instead. Guess I'm just not sure if those 2 analog outputs from the wideband are interchangeable.
Thanks for any suggestions. :biggrin:
