Large parts list left over from V8 swap
the prices were what I paid for them when they were new. only use as a guide if you make an offer, all parts have 3k miles on them. my email which is best to contact me at is mattbrisbon@gmail.com :6:
price item
if
new
40 lower radiator hose used
50 belt used
6 oil cooler o-ring new
50 power steering pulley used
200 power steering pump new
65 power steering lines new
150 starter new
50 coolant piped at intake to heater core, used
170 MAF used
100 MAF pipe powder coated w/hoses SOLD
50 oil cooler hoses, stock style new SOLD
20 evap canister, used with new filter and solenoid
34 used water pump
?? cruise control assembly at fender
124ea ignition control moduals, two available, used
350ea coil packs, used two available
?? coil pack/ign modual mount bracket SOLD
125 stock harmonic balancer and pulley
130 fuel pressure regulator, billet, accufab
50 fuel injector rail, used
20ea stock motor mounts, new
?? vaccumm hard line set, used
300 intake manifold, ported to gaskets, silver powder coated
40 thermostat billet nipple w 6 deg thermostat, used
?? accessory steel mount tube shaped brackets powdercoated
200 tensioner, belt - used SOLD
279 downpipe 3" cottons performance for external wastegate, used
500 rg-45 external wastegate used
65 braided teflon swivel turbo oil drain
1300 Turbo 66 series BBturbonetics f1 wheel w/g port bored,used
600 Header set with crossover Postons ceramic SOLD
500 exhaust cat back 3" SS used (pickup only)
100 stock electric fan, used SOLD
330 injectors 60lb mototron
56 arp main stud kit, NEW
100 ECM stock used with 94 TT chip (85$)
150 turbo saver billet oil system, used with extra filters
200 Fuel lines at front cover SS, used
25 gage pod, a piller new
150 gage pod a piller with digital boost and a/f gage used no senders
65 dipstick tube and stick, used painted
175 A/C hoses and lines, used with crimped on r134a adapter manifold
200 rebuilt stock alternator, used
174 ESM modual, used
200 a/c compressor used
unpriced all used
set main caps with two extras stock used
set of stock rods used
new stock rocker shaft and rocker set used
stock pushrod set used
turbo crank
turbo crank
turbo crank
hypertetic pistons 60 over w new rings
speed pro forged pistons 30 over used
8445 stock set of heads,used bare
8445 ported set of heads with oversized ss valves and roller cam kit springs hd SOLD
shafts and stock rockers with roller cam setup reusuable full throttle 210/215 SOLD
race built block 10psi oil pressure on first run 40 over forged pistons stock
rods and crank roller cam billet main caps.all arp, main studs headbolts and rod bolts
60 over fresh stock block with new stock cam and bearings
Thanks Matt! Got everything today as promised and exactly what you said it was! Awesome guy to deal with! Thanks again
