Trying to get the trans out. It's on the transjack and I want to roll it out. Can I just jack up the front and use jackstands or do I also need to put jackstands on the back to keep the car level?
I've done this a few times on a garage floor with no lift. Here's what I have to do to get the trans out. The key is to get the car high enough into the air that the bellhousing can fit between the frame rail and the floor while the trans is on the jack, which is a b_tch... This requires two floor jacks to do...
1. Jack up the front end with my SUV floor jack and set it down on jack stands.
2. Jack up the rear end with my SUV floor jack and set it down either on jack stands or a pair of ramps (if your jack can go high enough, you can just shove a pair of ramps under the rear wheels).
3. Place about 4 or 5 1X12's stacked on top of each other under the SUV floor jack and continue to lift the front end until it's really high. If you can put some tall jack stands under the frame somewhere for safety, that would be a good idea.
4. I then attach a short piece of 1X12 (about a foot long or so) to the top of my other floor jack. Basically, it's a piece of wood where I've made a through-hole and large counterbore. I put a bolt through the hole, and the couterbore is deep enough that the bolt head is below the surface of the wood. The bolt also goes through the hole in the jack, so I can put a nut on the end of the bolt to hold it and the board to the jack. I then adjust the jack so that the board goes under the trans pan and supports its weight.
5. I remove all of the bolts that are holding the trans in (bellhousing, cross-member, etc.) and lower the trans using the jack-and-board.
6. I then roll the trans out from under the car, very carefully.
With this set-up, I've been able to R&R a trans completely by myself. It takes a long time to jack-up the car using this method, but it does allow me to roll the trans out without too much trouble.
Of course, if you know anybody with a lift, for Pete's sake use it. Much easier.
