So now I have an intake manifold with ported runners and a stock intercooler.
I was thinking about doing an EGR blockoff as the EGR is plugged solid.
I will be removing the necks on the intercooler and doing a "big neck" conversion (of sorts).
The intercooler will be mounted upside down right behind the grill, front-mount style.
I will be switching to an electric fan and larger V8-style rad to make room for the piping.
The turbo will be reclocked but kept in the same location, as will the throttle body.
Should I run the return piping from the intercooler into the back of the intake (stock location), or should I modify the intake (remove the raised heatsink-looking front-top portion and replace it with a flat low profile plate) to allow for a front entry and block off the stock location?
I have heard of people removing the bottom of the intake, hollowing out the internals, and then welding on a plate to seal it back up. Good idea or no?
What are everyone's thoughts?
