Ignition module
boosted84
i have the 84 module with an adapter for the 87 coil well i think my mod is bad and is the root of my miss problem do i need anything special or can i just get an 87 module and bolt it in
thanks Anthony
rredalty
I just did this conversion last week. If you are still running the 84 harness, then you have 2 options: 1 being that you can buy the wireing adapter from caspers or 2 you can get the instructions off of gnttype.org to cut and splice the current harness. I chose to do the second and it took me about 1.5 hours to do it. The key to it is you have to know what you are doing to cut and splice and you MUST label the wires!!!!! I had the mounting bracket from caspers allready and if you don't choose to use it, you have to make a bracket to mount it as well. The caspers adapter harness works well from what i have heard, but it wansn't worth the $60 or so when i could do the same for free. Another tip is to extend all the wires approx 3-4in as the stock harness doesn't leave much slack. Hope this helps and if you have any other questions feel free to ask. I'm sure i have forgotten some other details. -Matt
turbo6x2
10 second hot air
I think the caspers method is easier and you really need to make sure you get a gm ignition module and not an after market one. The after market ignition modules don't work as well and tend to fail. Again My two cents.
HotAirWH1
Wow. good info. I'd like to stay with stock but may be forced into the adapter option if I cannot locate the 85 module. Anyone try the Kerban retro kit?
626gn
If you can't find a 84/85 module, I happen to have a conversion kit to a 86/87 style module complete with the metal mounting bracket. It was included in a bulk parts purchase I made a few years ago. I don't have a hot air car so I have no use for it and more importantly I CANNOT GUARANTEE IT WORKS because I am unable to test it. But if you want to try it I'll send it out to you. Here is a pic of what I have:
dank GN
BlackArts Automotive (661)993-8277
You have to swap some wires around and then just buy a 87 coil module and install it
626gn
I'll give HotAirWH1 another day to decide if he wants the conversion kit I have since I offered it to him first, if not it will go the person who PM'd me.
