gents,
forgive me if this gets long, but i'm gonna try to describe my predicament to the best of my ability via computer.
i just installed alky, raised the boost to 23psi and 2 days later my autozone coil starts missing (no surprise) i bought a used but known good delco coil pack/module off of a board member and i put it on. no more stumble and miss at random at 10 in/hg, runs smooth as a top up to ~15psi, after 15 tho, it lays over. with the cutout closed, no sounds are audible, it just stops accelerating, so i opened the cutout and whoa! lots of sound. the best way to describe it, it sounds like a drag car, at the staging light, bouncing off the launch control rev limiter. it bogs and and stops revving/accelerating at 15psi every time. but anything less than 15, she runs like a champ without the slighest problem. this is leading me to believe that the different coil/module is not the culprit. my question is this: 1) why would this problem not surface with the old AZ coil, and how are the problems so different with only a coil/module change? sorry if this is too vague to do anything with, but i'd like to get this solved before BPG next weekend, and i really really can't afford to just throw parts at it, (or i would have already). any insight y'all might be able to share is greatly appreciated.
thank you much!!
Talon
thank you much!!
Talon
