idle
jlat
hello people: What RPM does your TB idle at? Mines up and down and rarely the same. Today it was good at about 800 when I pulled up at work.
IBBY
Jerryl
Tall Chinese Guy
I run an aftermarket ECU and have full control over the idle rpm. IIRC, its set to 825 but the cam plays a big role in target rpm.
Stock cam has about 775 target in Park, without AC or coolant fan running IIRC.
jlat
jlat
Hello people: What helped my idle in the past was to clean up that valve (pintle?) that's next to trottle body but I've been lazy to do it. Has any one tried any additives
that's suppose to clean things up? I use only Shell hi test so fuel quality is not a problem.
IBBY
KC87
What about the IAC valve, could be sticking or intermittent at times. Had one give out years ago and had about a 2000rpm idle at times. New one fixed that.
